ArcGIS.Desktop.Mapping Namespace / WMSSubLayer Class
Members Example
    WMSSubLayer Class
    Represents a WMS sublayer.
    Object Model
    WMSSubLayer ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassSpatialReference ClassTimeParameters ClassSurfaceZsResult ClassMap ClassILayerContainer InterfaceEnvelope Class
    Syntax
    Example
    Adding and changing styles for WMS Service Layer
        var serverConnection = new CIMInternetServerConnection { URL = "https://spritle.esri.com/arcgis/services/sanfrancisco_sld/MapServer/WMSServer" };
        var connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
        LayerCreationParams parameters = new LayerCreationParams(connection);
        parameters.MapMemberPosition = MapMemberPosition.AddToBottom;
        //Note: Needs QueuedTask to run
        var compositeLyr = LayerFactory.Instance.CreateLayer<WMSLayer>(parameters, MapView.Active.Map);
        //wms layer in ArcGIS Pro always has a composite layer inside it
        var wmsLayers = compositeLyr.Layers[0] as ServiceCompositeSubLayer;
        //each wms sublayer belongs in that composite layer
        var highwayLayerWMSSub = wmsLayers.Layers[1] as WMSSubLayer;
        //toggling a sublayer's visibility
        if ((highwayLayerWMSSub != null))
            bool visibility = highwayLayerWMSSub.IsVisible;
            highwayLayerWMSSub.SetVisibility(!visibility);
        //applying an existing style to a wms sub layer
        var pizzaLayerWMSSub = wmsLayers.Layers[0] as WMSSubLayer;
        var currentStyles = pizzaLayerWMSSub.GetStyleNames();
        pizzaLayerWMSSub.SetStyleName(currentStyles[1]);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.WMSSubLayer
    Requirements
