ArcGIS.Desktop.Mapping Namespace / ProportionalRendererDefinition Class / ProportionalRendererDefinition Constructor / ProportionalRendererDefinition Constructor(String,esriUnits,CIMSymbolReference,SymbolShapes,ValueRepresentations)
Name of the field used in the renderer.
The units used in the renderer.
The fill to be used in symbol type set by using proportionalSymbolType.
(Optional) The symbol type for a proportional renderer. Only symbol type of circle or square is allowed. (default value = Circle)
(Optional) The value representation used in a proportional renderer. (default value = Radius)
    Creates a ProportionalRendererDefinition.
    Syntax
    Parameters
    field
    units
    symbolFill
    valueRepresentations
    Remarks
    Use this constructor only when the map is in a Projected Coordinate System.
    When the map is in a projected coordinated system and Units is set, use this constructor to symbolize features where the value of the feature gets used as the radius or the area of the symbol (depending on valueRepresentations).
    Requirements
