ArcGIS.Core.CIM Namespace / CIMAnimationScreenGraphicKeyframe Class
Properties Methods Events
    CIMAnimationScreenGraphicKeyframe Class Members
    The following tables list the members exposed by CIMAnimationScreenGraphicKeyframe.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the horizontal placement percent of the graphic anchor position on the viewer (0 is left edge, 1 is right edge).
    Public Property Gets or sets the vertical placement percent of the graphic anchor position on the viewer (0 is top edge, 1 is bottom edge).
    Public Property Gets or sets the pixel height for the graphic. It applies only to the animation screen graphic that contains a polygon graphic.
    Public Property Gets or sets the pixel width for the graphic. It applies only to the animation screen graphic that contains a polygon graphic.
    Public Property Gets or sets the angle of rotation (in degrees) for the graphic. It applies only to the animation screen graphic that contains a polygon graphic.
    Public Property Gets or sets the size multiplier for the graphic.
    Public Property Gets or sets the time in seconds relative to the beginning of the track.
    Public Property Gets or sets the transparency of the graphic as a percentage.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAnimationScreenGraphicKeyframe.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAnimationScreenGraphicKeyframe with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAnimationScreenGraphicKeyframe and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
