ArcGIS.Core.CIM Namespace / CIMMapGrid Class
Properties Methods Events
    CIMMapGrid Class Members
    The following tables list the members exposed by CIMMapGrid.
    Public Properties
     NameDescription
    Public Property Gets or sets the minimum length of the edge of the mapFrame polygon in page units.
    Public Property Gets or sets a value indicating whether the grid or graticule is visible.
    Public Property Gets or sets the map grid edges.
    Public Property Gets or sets the maximum value of the interior angle that determines the edge of the mapFrame polygon. The angle is defined in degrees.
    Public Property Gets or sets the maximum scale.
    Public Property Gets or sets the minimum scale.
    Public Property Gets or sets the name of the Grid or Graticule.
    Public Property Gets or sets the neat line symbol of the Grid or Graticule.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
