public CIMLabelClass[] LabelClasses {get; set;}
Public Property LabelClasses As CIMLabelClass()
await QueuedTask.Run(() =>
//Get the layer's definition, using the community sample Data\Admin\AdminSample.aprx
if (featureLayer.GetDefinition() is not CIMFeatureLayer lyrDefn)
// not a feature layer, leave
return;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//set the label class Expression to use the Arcade expression
theLabelClass.Expression = "return $feature.STATE_NAME + TextFormatting.NewLine + $feature.POP2000;";
//Set the label definition back to the layer.
featureLayer.SetDefinition(lyrDefn);
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Set the label classes' symbol to the custom text symbol
//Refer to the ProSnippets-TextSymbols wiki page for help with creating custom text symbols.
//Example: var textSymbol = await CreateTextSymbolWithHaloAsync();
theLabelClass.TextSymbol.Symbol = textSymbol;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
//set the label's visibility
featureLayer.SetLabelVisibility(true);
var map = MapView.Active?.Map;
if (map == null)
return;
//Modify label Placement
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine =
map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties) //Current labeling engine is Standard labeling engine
theLabelClass.StandardLabelPlacementProperties.PointPlacementMethod =
StandardPointPlacementMethod.OnTopPoint;
else //Current labeling engine is Maplex labeling engine
theLabelClass.MaplexLabelPlacementProperties.PointPlacementMethod =
MaplexPointPlacementMethod.CenteredOnPoint;
