ArcGIS.Desktop.Mapping.Controls Namespace / CoordinateSystemsControlProperties Class / Map Property
    Map Property (CoordinateSystemsControlProperties)
    Gets and sets the map whose layers will be used to populate the 'Layers' leaf in the CoordinateSystemsControl.
    Syntax
    public Map Map {get; set;}
    Public Property Map As Map
    Remarks
    Map is optional. The default is null. If a map is set then its layers will populate the Layers leaf node in the CoordinateSystemsControl otherwise no layers are shown.
    Requirements
