ArcGIS.Core.CIM Namespace / CIMMeasuredGrid Class
Properties Methods Events
    CIMMeasuredGrid Class Members
    The following tables list the members exposed by CIMMeasuredGrid.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to clip the grid to the UTM zone. If the measured grid is not defined in one of the UTM coordinates, then this property is irrelevant.
    Public Property Gets or sets the custom origin of the measured grid.
    Public Property Gets or sets the minimum length of the edge of the mapFrame polygon in page units. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the gridLines of the measured grid.
    Public Property Gets or sets a value indicating whether to auto-scale the grid.
    Public Property Gets or sets a value indicating whether the grid or graticule is visible. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the map grid edges. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the maximum value of the interior angle that determines the edge of the mapFrame polygon. The angle is defined in degrees. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the name of the Grid or Graticule. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the neat line symbol of the Grid or Graticule. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the projected coordinate system of the grid.
    Public Property Gets or sets a value indicating whether to use the clip shape of the map (if set) as the grid boundary.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMeasuredGrid.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMeasuredGrid with a specified state from a JSON encoding.
    Public Method Get the Projected Coordinate System of the CIMMeasuredGrid.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Set the Projected Coordinate System of the CIMMeasuredGrid.
    Public MethodOverridden.  Creates a JSON encoding of the CIMMeasuredGrid and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
