ArcGIS.Core.CIM Namespace / CIMGeometricEffectDashes Class / CustomEndingOffset Property
    CustomEndingOffset Property (CIMGeometricEffectDashes)
    Gets or sets where the pattern should end relative to the ending point of the geometry. Negative numbers indicate a shift to the left and positive numbers a shift to the right. This property is only applied if the LineDashEnding is set to Custom.
    Syntax
    public double CustomEndingOffset {get; set;}
    Public Property CustomEndingOffset As Double
    Requirements
