ArcGIS.Core.CIM Namespace / CIMGeometricEffectDashes Class
Properties Methods Events
    CIMGeometricEffectDashes Class Members
    The following tables list the members exposed by CIMGeometricEffectDashes.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the line dash ending position.
    Public Property Gets or sets where the pattern should end relative to the ending point of the geometry. Negative numbers indicate a shift to the left and positive numbers a shift to the right. This property is only applied if the LineDashEnding is set to Custom.
    Public Property Gets or sets the distance for each dash and gap. There can be multiple dash and gap values to form a complex pattern.
    Public Property Gets or sets the setting which determines how the strokes with dash patterns and other patterns (pictures, placement effects) are handled at the end points of the line geometry's segments.
    Public Property Gets or sets the position where the pattern should begin relative to the starting point of the geometry. It shifts the entire pattern along the line the specified distance. Negative values indicate a shift to the left and positive numbers a shift to the right. This property is only applied if LineDashEnding is set to NoConstraint or Custom.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeometricEffectDashes.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeometricEffectDashes with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeometricEffectDashes and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
