ArcGIS.Desktop.Core Namespace / GeoprocessingOptions Class / SetWriteGPOperationsToDataset Method
Boolean indicating if tool information is written to the tool's input and output dataset metadata.
    Sets whether information about the tools being run is written to the tool's input and output dataset metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetWriteGPOperationsToDataset(
       bool writeGPOperationsToDataset
    Public Sub SetWriteGPOperationsToDataset( _
       ByVal writeGPOperationsToDataset As Boolean _
    Parameters
    Exceptions
    ExceptionDescription
    Remarks
    Note: see ArcGIS.Desktop.Core.Geoprocessing.GPExecuteToolFlags for available options for modifying behavior of ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ExecuteToolAsync. Changing these parameters modifies behavior of interactive GP tools
    Requirements
    ArcGIS Pro version: 3.1 or higher.
