ArcGIS.Core.CIM Namespace / CIMChartTimeBinningProperties Class
Properties Methods Events
    CIMChartTimeBinningProperties Class Members
    The following tables list the members exposed by CIMChartTimeBinningProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the time interval units and size are automatically calculated.
    Public Property Gets or sets the reference time value. Valid when TimeAggregationType property is set to ReferenceTime.
    Public Property Gets or sets the time aggregation type.
    Public Property Gets or sets the time interval size.
    Public Property Gets or sets the units used for the time interval size.
    Public Property Gets or sets a value indicating whether incomplete time intervals at the ends of time interval ranges are trimmed in order to avoid bias.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartTimeBinningProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartTimeBinningProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartTimeBinningProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
