ArcGIS.Core.CIM Namespace / CIMGeotriggerDeviceLocationFeed Class
Properties Methods Events
    CIMGeotriggerDeviceLocationFeed Class Members
    The following tables list the members exposed by CIMGeotriggerDeviceLocationFeed.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the arcade expression that controls whether a location update will be used by a geotrigger. This expression uses the Location Update Constraint Arcade profile. The expression should return a Boolean where false indicates the location will not be used.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeotriggerDeviceLocationFeed.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeotriggerDeviceLocationFeed with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeotriggerDeviceLocationFeed and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
