ArcGIS.Core.CIM Namespace / CIMLinkChartPropertyFilter Class
Properties Methods Events
    CIMLinkChartPropertyFilter Class Members
    The following tables list the members exposed by CIMLinkChartPropertyFilter.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the property data type that will be filtered.
    Public Property Gets or sets the description of the link chart filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets a value indicating whether the link chart filter is enabled or not. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the value that indicates what link chart component is filtered: entities, relationships, or both. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the value that indicates when the link chart filter is applied. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the filter type of the link chart filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the ID of the link chart filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets a value indicating whether or not this is an exclusion filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the name of the link chart filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the entity and or relationship Ids to filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Public Property Gets or sets the binary reference of the filter values for the link chart filter. (Inherited from ArcGIS.Core.CIM.CIMLinkChartFilter)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLinkChartPropertyFilter.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLinkChartPropertyFilter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLinkChartPropertyFilter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
