ArcGIS.Core.Data.UtilityNetwork Namespace / Subnetwork Class / GetLineFeature Method
    Returns the ArcGIS.Core.Data.Feature from the SubnetLine table that corresponds to this subnetwork. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Feature GetLineFeature()
    Public Function GetLineFeature() As Feature
    Return Value
    The ArcGIS.Core.Data.Feature from the SubnetLine table that corresponds to this subnetwork.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Note that if Update has not yet been called, or if the subnetwork does not contain any features with an AssetType, returned by Tier.ValidSubnetworkLines, the feature may not exist.
    Requirements
