ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / CreateElement Method / CreateElement(AssetType,Guid) Method
The AssetType of the row used to create the Element.
The global ID of the row used to create the Element.
Example
    Creates an Element object, which represents a Row (or Row + Terminal) in a utility network. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateElement( _
       ByVal assetType As AssetType, _
       ByVal globalID As Guid _
    ) As Element
    public Element CreateElement(
       AssetType assetType,
       Guid globalID
    Parameters
    assetType
    globalID
    Return Value
    An Element object corresponding to globalID from a NetworkSource associated with assetType.
    Exceptions
    ExceptionDescription
    assetType is null.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    No default Terminal is assigned. This overload allows the creation of a Element when no ArcGIS.Core.Data.Row is available. If you don't already have a Row object, fetching one requires an additional query (database query or round-trip call to the feature service). This constructor allows this extra call to be avoided.
    Example
    Create a utility network association
      // This routine creates a structural attachment association between a pole and a transformer bank
      static void CreateUNAssociation(UtilityNetwork utilityNetwork, AssetType poleAssetType, Guid poleGlobalID, AssetType transformerBankAssetType, Guid transformerBankGlobalID)
        // Create edit operation
        EditOperation editOperation = new EditOperation();
        editOperation.Name = "Create structural attachment association";
        // Create a RowHandle for the pole
        Element poleElement = utilityNetwork.CreateElement(poleAssetType, poleGlobalID);
        RowHandle poleRowHandle = new RowHandle(poleElement, utilityNetwork);
        // Create a RowHandle for the transformer bank
        Element transformerBankElement =
          utilityNetwork.CreateElement(transformerBankAssetType, transformerBankGlobalID);
        RowHandle transformerBankRowHandle = new RowHandle(transformerBankElement, utilityNetwork);
        // Attach the transformer bank to the pole
        AssociationDescription structuralAttachmentAssociationDescription =
          new AssociationDescription(AssociationType.Attachment, poleRowHandle, transformerBankRowHandle);
        editOperation.Create(structuralAttachmentAssociationDescription);
        editOperation.Execute();
    Requirements
