ArcGIS.Core.Data.Analyst3D Namespace / TinDatasetDefinition Class
Properties Methods
    TinDatasetDefinition Class Members
    The following tables list the members exposed by TinDatasetDefinition.
    Public Properties
     NameDescription
    Public PropertyOverridden. Gets the ArcGIS.Core.Data.DatasetType of the TIN dataset. Always returns ArcGIS.Core.Data.DatasetType.Tin.
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodGets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the TinDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Definition)
    Public MethodGets the ArcGIS.Core.Geometry.SpatialReference for the TinDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Top
