ArcGIS.Core.Data.UtilityNetwork Namespace / Subnetwork Class / Export Method
The path of a JSON file where the information about a subnetwork will be exported.
The options describing how a subnetwork will be exported.
Example
    Export Method (Subnetwork)
    Exports information about a subnetwork into a JSON file. This also deletes rows in the Subnetworks table that are marked as deleted.
    Syntax
    Parameters
    outputJsonPath
    subnetworkExportOptions
    Exceptions
    ExceptionDescription
    outputJsonPath must have the .json extension.
    outputJsonPath or subnetworkExportOptions is null.
    Export cannot be performed in an active edit session.
    A geodatabase-related exception has occurred.
    Example
    Export Subnetwork
      // This routine exports a subnetwork to a JSON file
      static void ExportSubnetwork(UtilityNetwork utilityNetwork, string subnetworkName, Uri exportResultJsonPath)
        using UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition();
        using SubnetworkManager subnetworkManager = utilityNetwork.GetSubnetworkManager();
        Subnetwork subnetwork = subnetworkManager.GetSubnetwork(subnetworkName);
        IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
        IReadOnlyList<NetworkSource> networkSources = utilityNetworkDefinition.GetNetworkSources();
        NetworkSource electricDevice = networkSources.First(f => f.Name.Contains("ElectricDevice"));
        // Export options
        SubnetworkExportOptions subnetworkExportOptions = new()
          SetAcknowledged = false,
          IncludeDomainDescriptions = true,
          IncludeGeometry = true,
          ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
          SubnetworkExportResultTypes = new List<SubnetworkExportResultType>()
            SubnetworkExportResultType.Connectivity,
            SubnetworkExportResultType.Features
          ResultNetworkAttributes = new List<NetworkAttribute>(networkAttributes),
          ResultFieldsByNetworkSourceID = new Dictionary<int, List<string>>()
            { { electricDevice.ID, new List<string>() { "AssetID" } } }
        subnetwork.Export(exportResultJsonPath, subnetworkExportOptions);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
