ArcGIS.Core.Data.UtilityNetwork Namespace / Subnetwork Class / Update Method / Update(TraceConfiguration,ServiceSynchronizationType) Method
The argument to override the default trace configuration stored on the Tier.
Specifies which implementation of the service endpoint to call. This parameter is ignored for non-services based utility networks.
Example
    Updates the subnetwork. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    traceConfiguration
    serviceSynchronizationType
    Exceptions
    ExceptionDescription
    traceConfiguration is null.
    This subnetwork no longer exists (e.g., it has been purged from the database).
    -or-
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when editing is in progress.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    • This routine generates its own editing transaction, and therefore cannot be wrapped in a separate transaction. Because the editing performed by this routine cannot be undone, this routine can also not be called within an editing session. All edits in the current edit session must be saved or discarded before calling this routine.
    • If the preexisting subnetwork state is Dirty or Clean, the new state will be Clean if successful.
    • If the preexisting subnetwork state is DirtyAndDeleted or CleanAndDeleted, the new state will be CleanAndDeleted if successful.
    • When running in a Pro add-in, ArcGIS.Desktop.Mapping.MapView.Redraw should be called with a true argument to refresh the display cache and redraw the map.
    Example
    Life cycle for a simple radial subnetwork with one controller
      // This routine demonstrates the life cycle of a simple radial subnetwork with one controller
      static void RadialNetworkLifecycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR1)
        // Create a subnetwork named "Radial1" with a single controller
        // elementR1 represents the device that serves as the subnetwork controller (e.g., circuit breaker)
        Subnetwork subnetworkRadial1 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR1,
          "Radial1", "R1", "my description", "my notes");
        // Update the subnetwork and refresh the map
        subnetworkRadial1.Update();
        MapView.Active.Redraw(true);
        // At some point, a subnetwork will need to be deleted.
        // First step is to disable the controller
        subnetworkManager.DisableControllerInEditOperation(elementR1);
        // At this point, the subnetwork is deleted, but all of the rows that have been labeled with the subnetwork ID need to be updated
        // The final step is to notify external systems (if any) by exporting the subnetwork
        SubnetworkExportOptions subnetworkExportOptions = new SubnetworkExportOptions()
          SetAcknowledged = true,
          IncludeDomainDescriptions = true,
          IncludeGeometry = true,
          ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
          SubnetworkExportResultTypes = new List<SubnetworkExportResultType>()
            SubnetworkExportResultType.Features
          // Set networks attributes and attribute fields to export
          //ResultNetworkAttributes = new List<NetworkAttribute>(networkAttributes),
          //ResultFieldsByNetworkSourceID = new Dictionary<int, List<string>>()
          //  { { electricDevice.ID, new List<string>() { "AssetID" } } }
        subnetworkRadial1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"),
          subnetworkExportOptions);
    Life cycle for a mesh subnetwork with multiple controllers
      // This routine demonstrates the life cycle of a mesh subnetwork with multiple controllers
      static void MeshNetworkLifeCycle(SubnetworkManager subnetworkManager, Tier lowVoltageMeshTier,
      Element elementM1, Element elementM2, Element elementM3)
        // Create a subnetwork named "Mesh1" from three controllers
        // elementM1, elementM2, and elementM3 represent the devices that serve as subnetwork controllers (e.g., network protectors)
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM1, "Mesh1", "M1", "my description", "my notes");
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM2, "Mesh1", "M2", "my description", "my notes");
        Subnetwork subnetworkMesh1 = subnetworkManager.EnableController(lowVoltageMeshTier, elementM3, "Mesh1", "M3",
        subnetworkMesh1.Update();
        // When deleting the subnetwork, each controller must be disabled before the subnetwork itself is deleted
        subnetworkManager.DisableControllerInEditOperation(elementM1);
        subnetworkManager.DisableControllerInEditOperation(elementM2);
        subnetworkManager.DisableControllerInEditOperation(elementM3);
        // After the subnetwork is deleted, all of the rows that have been labeled with the subnetwork ID need to be updated
        subnetworkMesh1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"), subnetworkExportOptions);
    Life cycle for a multifeed radial subnetwork with two controllers
      // This routine demonstrates the life cycle of a multifeed radial subnetwork with two controllers
      static void MultifeedRadialLifeCycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR2, Element elementR3)
        // Create a subnetwork named "R2, R3" from two controllers
        // elementR2 and elementR3 represent the devices that serve as subnetwork controllers (e.g., circuit breakers)
        subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2, R3", "R2",
        subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R2, R3", "R3",
        // If the tie switch between them is opened, the original subnetwork controllers must be disabled and re-enabled with different names
        // This will create two new subnetworks, named "R2" and "R3"
        subnetworkManager.DisableControllerInEditOperation(elementR2);
        subnetworkManager.DisableControllerInEditOperation(elementR3);
        Subnetwork subnetworkR2 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2",
          "R2", "my description", "my notes");
        Subnetwork subnetworkR3 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R3",
          "R3", "my description", "my notes");
        subnetworkR2.Update();
        subnetworkR3.Update();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
