ArcGIS.Core.Data.UtilityNetwork Namespace / SubnetworkExportOptions Class / SetAcknowledged Property
Example
    SetAcknowledged Property (SubnetworkExportOptions)
    Specifies whether the export is acknowledged. If true the default version is required.
    Syntax
    public bool SetAcknowledged {get; set;}
    Public Property SetAcknowledged As Boolean
    Remarks
    Acknowledge export to delete the record of any subnetwork controllers from the subnetworks table that have been removed as a subnetwork controller. Acknowledge is not necessary if there are no controllers that need to be deleted from the subnetworks table.
    Example
    Life cycle for a simple radial subnetwork with one controller
      // This routine demonstrates the life cycle of a simple radial subnetwork with one controller
      static void RadialNetworkLifecycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR1)
        // Create a subnetwork named "Radial1" with a single controller
        // elementR1 represents the device that serves as the subnetwork controller (e.g., circuit breaker)
        Subnetwork subnetworkRadial1 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR1,
          "Radial1", "R1", "my description", "my notes");
        // Update the subnetwork and refresh the map
        subnetworkRadial1.Update(new SubnetworkUpdateOptions());
        MapView.Active.Redraw(true);
        // At some point, a subnetwork will need to be deleted.
        // First step is to disable the controller
        subnetworkManager.DisableControllerInEditOperation(elementR1);
        // At this point, the subnetwork is deleted, but all of the rows that have been labeled with the subnetwork ID need to be updated
        // The final step is to notify external systems (if any) by exporting the subnetwork
        SubnetworkExportOptions subnetworkExportOptions = new SubnetworkExportOptions()
          SetAcknowledged = true,
          IncludeDomainDescriptions = true,
          IncludeGeometry = true,
          ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
          SubnetworkExportResultTypes = new List<SubnetworkExportResultType>()
            SubnetworkExportResultType.Features
          // Set networks attributes and attribute fields to export
          //ResultNetworkAttributes = new List<NetworkAttribute>(networkAttributes),
          //ResultFieldsByNetworkSourceID = new Dictionary<int, List<string>>()
          //  { { electricDevice.ID, new List<string>() { "AssetID" } } }
        subnetworkRadial1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"),
          subnetworkExportOptions);
    Life cycle for a mesh subnetwork with multiple controllers
      // This routine demonstrates the life cycle of a mesh subnetwork with multiple controllers
      static void MeshNetworkLifeCycle(SubnetworkManager subnetworkManager, Tier lowVoltageMeshTier,
      Element elementM1, Element elementM2, Element elementM3)
        // Create a subnetwork named "Mesh1" from three controllers
        // elementM1, elementM2, and elementM3 represent the devices that serve as subnetwork controllers (e.g., network protectors)
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM1, "Mesh1", "M1", "my description", "my notes");
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM2, "Mesh1", "M2", "my description", "my notes");
        Subnetwork subnetworkMesh1 = subnetworkManager.EnableController(lowVoltageMeshTier, elementM3, "Mesh1", "M3",
        subnetworkMesh1.Update(new SubnetworkUpdateOptions());
        // When deleting the subnetwork, each controller must be disabled before the subnetwork itself is deleted
        subnetworkManager.DisableControllerInEditOperation(elementM1);
        subnetworkManager.DisableControllerInEditOperation(elementM2);
        subnetworkManager.DisableControllerInEditOperation(elementM3);
        // After the subnetwork is deleted, all of the rows that have been labeled with the subnetwork ID need to be updated
        subnetworkMesh1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"), subnetworkExportOptions);
    Export Subnetwork
      // This routine exports a subnetwork to a JSON file
      static void ExportSubnetwork(UtilityNetwork utilityNetwork, string subnetworkName, Uri exportResultJsonPath)
        using UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition();
        using SubnetworkManager subnetworkManager = utilityNetwork.GetSubnetworkManager();
        Subnetwork subnetwork = subnetworkManager.GetSubnetwork(subnetworkName);
        IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
        IReadOnlyList<NetworkSource> networkSources = utilityNetworkDefinition.GetNetworkSources();
        NetworkSource electricDevice = networkSources.First(f => f.Name.Contains("ElectricDevice"));
        // Export options
        SubnetworkExportOptions subnetworkExportOptions = new()
          SetAcknowledged = false,
            SubnetworkExportResultType.Connectivity,
        subnetwork.Export(exportResultJsonPath, subnetworkExportOptions);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
