ArcGIS.Core.Data.UtilityNetwork Namespace / SubnetworkExportOptions Class
Properties
    SubnetworkExportOptions Class Members
    The following tables list the members exposed by SubnetworkExportOptions.
    Public Constructors
     NameDescription
    Public ConstructorInitializes a new instance of the SubnetworkExportOptions class to export a Subnetwork.
    Top
    Public Properties
     NameDescription
    Public Property Specifies whether domain descriptions will be included in the resulting JSON file. (Inherited from ArcGIS.Core.Data.UtilityNetwork.ExportOptions)
    Public Property Specifies whether to include flow direction results.
    Public Property Specifies whether geometry will be included in the results.
    Public Property Specifies whether to include propagated value results.
    Public Property Specifies additional related record field values to be returned during export.
    Public Property The names of the fields from a network source that will be returned as results.
    Public Property The network attributes that will be included in the results.
    Public Property Specifies if this operation should run asynchronously. (Inherited from ArcGIS.Core.Data.UtilityNetwork.ExportOptions)
    Public PropertySpecifies whether the export is acknowledged. If true the default version is required.
    Public Property Specifies the types of results that will be returned.
    Top
