ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / LoopsTracer Class / Trace Method / Trace(TraceArgument,ServiceSynchronizationType) Method
The input arguments to the trace.
Specifies which implementation of the service endpoint to call. This parameter is ignored for non-services based utility networks.
    Executes a loop trace.
    Syntax
    Parameters
    traceArgument
    serviceSynchronizationType
    Return Value
    A IReadOnlyList of concrete Result whose type corresponds to ResultType set in TraceArgument.ResultTypes.
    Exceptions
    Requirements
    ArcGIS Pro version: 3.2 or higher.
