ArcGIS.Desktop.Mapping Namespace / IMapFactory Interface / CreateLocalBasemap Method
The name of the base map
    CreateLocalBasemap Method (IMapFactory)
    Creates a local basemap of MapType.Basemap ArcGIS.Core.CIM.MapType. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function CreateLocalBasemap( _
       ByVal name As String _
    ) As Map
    Map CreateLocalBasemap(
       string name
    Parameters
    name
    Return Value
    Exceptions
    ExceptionDescription
    Requirements
