ArcGIS.Core.CIM Namespace / CIMChartGuide Class
Properties Methods Events
    CIMChartGuide Class Members
    The following tables list the members exposed by CIMChartGuide.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the symbol properties for the guide.
    Public Property Gets or sets the type of the guide.
    Public Property Gets or sets the type of the coordinate value used in the guide.
    Public Property Gets or sets the label for the guide.
    Public Property Gets or sets the relative position of the label to the guide.
    Public Property Gets or sets the text format for the guide label.
    Public Property Gets or sets the marker symbol properties for the guide.
    Public Property Gets or sets the name / title for the guide.
    Public Property Gets or sets vertices of the polyline guide as an array of x and y coordinates in a row-major order.
    Public Property Gets or sets the temporal coordinate of the from value for the guide. This value will be used when guide value type is set to temporal.
    Public Property Gets or sets the temporal coordinate of the to value for the guide. This value will be used when guide value type is set to temporal.
    Public Property Gets or sets the numeric coordinate of the from value for the guide. This value will be used when guide value type is set to numeric.
    Public Property Gets or sets the field name for calculation of the numeric coordinate of the from value for the guide. This value will be used when guide value type is set to numeric.
    Public Property Gets or sets the aggregation type for calculation of the numeric coordinate of the from value for the guide. This value will be used when guide value type is set to numeric.
    Public Property Gets or sets the numeric coordinate of the to value for the guide. This value will be used when guide value type is set to numeric.
    Public Property Gets or sets a value indicating whether the guide is visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartGuide.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartGuide with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartGuide and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
