ArcGIS.Core.CIM Namespace / CIMChartProfileGraphSeries Class
    CIMChartProfileGraphSeries Class Properties
    For a list of all members of this type, see CIMChartProfileGraphSeries members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to chain lines together from end to end if their endpoints coincide.
    Public Property Gets or sets a threshold value determining whether line endpoints coincide in XY.
    Public Property Gets or sets a threshold value determining whether line endpoints coincide in Z.
    Public Property Gets or sets the type of color for the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the text style for the data label. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the aggregate field values if series data has a group field. Allowed values are count, sum, median, mean, and empty string. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets expression properties for chart series' fields. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the data field names in the series. Optional depending on series type. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether to flip the direction in which lines and chains are graphed.
    Public Property Gets or sets the group field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the index of horizontal axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the unit of measure to be used for horizontal distance. The default value is layer's spatial reference XY unit.
    Public Property Gets or sets a value indicating which line type to use in the graph.
    Public Property Gets or sets the line symbol properties of the profile graph series.
    Public Property Gets or sets the locations for which data is to be plotted. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the marker symbol properties of the profile graph series.
    Public Property Gets or sets a value indicating whether this series is a multi series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the name of the series shown in the legend. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the sort field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the array of sort order types for fields in OrderFields property Allowed values 0(Ascending), 1(Descending). (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the field names in the series. It contains three values (DirectionPreference, ChainingGrouping, and ChainBounds).
    Public Property Gets or sets a value indicating whether the series shows data labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether to draw a line connecting points from Line Of Sight output.
    Public Property Gets or sets a value indicating whether to draw points from Line Of Sight output.
    Public Property Gets or sets a value indicating whether in the map/scene to dynamically display cursor movement in the chart.
    Public Property Gets or sets the default and unique name of the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating which variable to display in the first Y axis.
    Public Property Gets or sets the index of vertical axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value by which to exaggerate the vertical axis relative to the horizontal axis.
    Public Property Gets or sets the unit of measure to be used for elevation. The default value is the layer's vertical coordinate system's Z unit, if there is one.
    Public Property Gets or sets a value indicating whether the series is visible or not. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the format string for series value labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Top
