| Name | Description | |
![]() | CIMDefinitionFilter Constructor |
The following tables list the members exposed by CIMDefinitionFilter.
![]() | DefinitionExpression | Gets or sets the definition expression to filter features in the dataset. |
![]() | FeatureIdentifierSetURI | Gets or sets the URI of the source layer's feature identifier set (identified by GlobalID or OID) used as the definition filter geometry. |
![]() | GeometrySource | Gets or sets the definition filter geometry source. |
![]() | GeometryURI | Gets or sets the URI to the geometry to filter features in the dataset. |
![]() | Name | Gets or sets the name of the Definition Filter item. |
![]() | SearchOrder | Gets or sets the search order option. |
![]() | SourceLayerURI | Gets or sets the source layer URI for feature-linked definition filter geometry. |
![]() | SpatialReference | Gets or sets the spatial reference of the definition filter geometry. |
![]() | Clone | Creates a deep copy of CIMDefinitionFilter. |
![]() ![]() | FromJson | Reconstructs the CIMDefinitionFilter with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMDefinitionFilter and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
