ArcGIS.Core.CIM Namespace / CIMViewshedEADefinition Class
Properties Methods Events
    CIMViewshedEADefinition Class Members
    The following tables list the members exposed by CIMViewshedEADefinition.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the heading in degrees from North. 0 is North, 90 is West, 180 is South, -90 is East, etc.
    Public Property Gets or sets the horizontal viewing angle.
    Public Property Gets or sets the id. (Inherited from ArcGIS.Core.CIM.CIMExploratoryAnalysisDefinition)
    Public Property Gets or sets the maximum distance to be analyzed.
    Public Property Gets or sets the minimum distance to be analyzed.
    Public Property Gets or sets the observer position.
    Public Property Gets or sets the pitch in degrees from horizontal. 0 is horizontal, 90 is looking directly up and -90 is looking directly down.
    Public Property Gets or sets the vertical viewing angle.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMViewshedEADefinition.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMViewshedEADefinition with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMViewshedEADefinition and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
