ArcGIS.Core.Data.PluginDatastore Namespace / PluginTableTemplate Class / Search Method / Search(SpatialQueryFilter) Method
A spatial query filter that specifies the search criteria.
    Performs a spatial search on this plug-in feature class that satisfies the criteria set in the spatialQueryFilter.
    Syntax
    Public Overloads MustOverride Function Search( _
       ByVal spatialQueryFilter As SpatialQueryFilter _
    ) As PluginCursorTemplate
    Parameters
    spatialQueryFilter
    Return Value
    A concrete instance of PluginCursorTemplate that encapsulates the retrieved rows.
    Exceptions
    ExceptionDescription
    Signals to the framework that an exception derived from System.Exception has occurred.
    Remarks
    Please see the additional constraints that may be imposed on this method in the remarks section of IsQueryLanguageSupported.
    Requirements
