ArcGIS.Core.Data Namespace / BimFileDatasetDefinition Class
Properties Methods
    BimFileDatasetDefinition Class Members
    The following tables list the members exposed by BimFileDatasetDefinition.
    Public Properties
     NameDescription
    Public PropertyOverridden. Gets the DatasetType of the BIM dataset.
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodGets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the BimFileDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the name of the definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Definition)
    Public MethodGets the ArcGIS.Core.Geometry.SpatialReference for the BimFileDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Top
