ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarker Method / ConstructMarker(CIMStroke,Double,Polygon) Method
The marker outline
The size of the marker to construct
The outline shape of the marker
    Constructs a marker of the stroke ("outline"), size, and shape.
    Syntax
    Overloads Function ConstructMarker( _
       ByVal outline As CIMStroke, _
       ByVal size As Double, _
       ByVal markerShape As Polygon _
    ) As CIMMarker
    Parameters
    outline
    The marker outline
    size
    markerShape
    Return Value
    Remarks
    The specified stroke is used to create a polygon symbol which is used to depict the marker. The polygon symbol will be hollow - i.e. it has a null fill
    Requirements
