ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructMarker Method / ConstructMarker(CIMFill,CIMStroke,Double,Polygon) Method
The marker fill. Null to make a hollow symbol
The marker outline
The size of the marker to construct
The outline shape of the marker
Example
    Constructs a marker of the specified shape, fill, outline, and size.
    Syntax
    Public Overloads Function ConstructMarker( _
       ByVal fill As CIMFill, _
       ByVal outline As CIMStroke, _
       ByVal size As Double, _
       ByVal markerShape As Polygon _
    ) As CIMMarker
    Parameters
    fill
    outline
    The marker outline
    size
    markerShape
    Return Value
    Remarks
    The specified stroke and fill create a polygon symbol which is used to depict the marker
    Example
    Modify a point symbol created from a character marker
        //create marker from the Font, char index,size,color
        //Note: Needs QueuedTask to run
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Requirements
