ArcGIS.Core.CIM Namespace / CIMKeyframeLayer Class
Properties Methods Events
    CIMKeyframeLayer Class Members
    The following tables list the members exposed by CIMKeyframeLayer.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the path to the layer.
    Public Property Gets or sets the direction to clip from an edge.
    Public Property Gets or sets the amount of the visible area to clip.
    Public Property Gets or sets the transparency of the keyframe as a percentage.
    Public Property Gets or sets the method of transition for the transparency of the layer.
    Public Property Gets or sets the vertical exaggeration.
    Public Property Gets or sets a value indicating whether the layer is visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKeyframeLayer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKeyframeLayer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKeyframeLayer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
