ArcGIS.Core.CIM Namespace / CIMChartCalendarHeatSeries Class
Properties Methods Events
    CIMChartCalendarHeatSeries Class Members
    The following tables list the members exposed by CIMChartCalendarHeatSeries.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the calendar heat chart view should be de-aggregated into consecutive calendars or aggregated into a single calendar.
    Public Property Gets or sets the color for each break.
    Public Property Gets or sets the upper bound breaks.
    Public Property Gets or sets the number of breaks for automatic breaks creation.
    Public Property Gets or sets the classification method with which breaks are created.
    Public Property Gets or sets the color ramp from which break colors are created.
    Public Property Gets or sets the type of color for the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the time units for columns.
    Public Property Gets or sets the text style for the data label. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the aggregate field values if series data has a group field. Allowed values are count, sum, median, mean, and empty string. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets expression properties for chart series' fields. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the data field names in the series. Optional depending on series type. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the group field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the index of horizontal axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether a leap day (February 29) cell is a part of a chart.
    Public Property Gets or sets the locations for which data is to be plotted. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the lower bound of the first range.
    Public Property Gets or sets a value indicating whether this series is a multi series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the name of the series shown in the legend. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets color properties for empty cells.
    Public Property Gets or sets the policy for handling missing data.
    Public Property Gets or sets the sort field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the array of sort order types for fields in OrderFields property Allowed values 0(Ascending), 1(Descending). (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the time units for rows.
    Public Property Gets or sets a value indicating whether the series shows data labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the default and unique name of the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the index of vertical axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether the series is visible or not. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the format string for series value labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartCalendarHeatSeries.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartCalendarHeatSeries with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartCalendarHeatSeries and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
