Public Property TraversalDirections As CIMKGTraversalDirection()
public CIMKGTraversalDirection[] TraversalDirections {get; set;}
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "Run FFP w Traversal Filters";
//set origin entities
//set destination entities
//set any path filters
//Set traversal filters
//A traversal filter is used to specify the traversal direction of a relationship (to be)
//included in the result paths. By default, paths are evaluated without considering the
//direction of relationships in the graph - i.e. KGTraversalDirectionType.Any.
//Relationships can be evaluated in specific directions by changing the KGTraversalDirectionType
//enum value of the traversal_filter.TraversalDirectionType.
//For example, the traversal direction is being set for the following relationship types...
var traversalFilters = new List<CIMKGTraversalDirection>();
foreach (var relation in new List<string> { "near_poi", "near_facility", "near_facility2" })
var traversal_filter = new CIMKGTraversalDirection();
traversal_filter.RelationshipTypeName = relation;
//All relationships of the specified type are considered (default)
traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Any;
//Relationship can only be traversed from origin to destination
traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Forward;
//Relationship can only be traversed from destination to origin
traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Backward;
traversalFilters.Add(traversal_filter);
ffp_config.TraversalDirections = traversalFilters.ToArray();
//etc.
//TODO - use the config
//var results = kg.RunFilteredFindPaths(ffp_config);
