ArcGIS.Core.CIM Namespace / CIMKGDurativeEventsDurationConstraint Class
Properties Methods Events
    CIMKGDurativeEventsDurationConstraint Class Members
    The following tables list the members exposed by CIMKGDurativeEventsDurationConstraint.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the maximum duration. The unit of maximum duration is TimeUnit. This value is only used if UseMaxDuration is true.
    Public Property Gets or sets the minimum duration. The unit of minimum duration is TimeUnit.
    Public Property Gets or sets the unit of minimum and maximum durations. Accepted values are { esriTimeUnitsMilliseconds, esriTimeUnitsSeconds, esriTimeUnitsMinutes, esriTimeUnitsHours, esriTimeUnitsDays, esriTimeUnitsWeeks }.
    Public Property Gets or sets a value indicating whether the maximum duration should be used.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKGDurativeEventsDurationConstraint.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKGDurativeEventsDurationConstraint with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKGDurativeEventsDurationConstraint and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
