ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphSpatialProperty Class
Properties Methods Events
    CIMKnowledgeGraphSpatialProperty Class Members
    The following tables list the members exposed by CIMKnowledgeGraphSpatialProperty.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the geometry type of the property. Currently, only allowed values: - esriGeometryPoint - esriGeometryMultipoint - esriGeometryPolyline - esriGeometryPolygon Others will be allowed in future.
    Public Property Gets or sets a value indicating whether all geometry values should be kept when merging. Only applies when GeometryType is a multi-part geometry.
    Public Property Gets or sets a value indicating whether this property should be used to determine a merge. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the value to use when import data is missing. This value is used when the Value property results in a null or empty value. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the name of the property. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the type of the property. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets a value describing how to handle spatial merge. If not set, there is no spatial merge.
    Public Property Gets or sets the spatial reference of the property.
    Public Property Gets or sets the value which is to be imported. Value will have to be tested for type in order to properly perform the import. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphSpatialProperty.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphSpatialProperty with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphSpatialProperty and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
