ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / AppendToLinkChart Method
The link chart to append to.
The set of named object types and records.
Example
    Appends a set of named object types and their records to the link chart map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub AppendToLinkChart( _
       ByVal linkChart As Map, _
       ByVal idSet As KnowledgeGraphLayerIDSet _
    public static void AppendToLinkChart(
       Map linkChart,
       KnowledgeGraphLayerIDSet idSet
    Parameters
    linkChart
    idSet
    Exceptions
    ExceptionDescription
    idSet cannot be null.
    Map is not a link chart or does not contain a Knowledge Graph layer or an empty ID set is specified.
    idSet contains invalid Name Object types..
    Remarks
    You should use CanAppendToLinkChart prior to this method.
    Add an entry to the idSet for each Named Object type to be appended along with a list of their relevant record ids. Specify a null or empty list for a given entry to include all the records for that particular type at the time of this operation.
    Note: Named Object names in an ID set entry are case-sensitive.
    If there are Named Object type names specified in the ID set that do not match a Named Object type name in the KnowledgeGraph then a KnowledgeGraphLayerException will be thrown. The exception will contain the list of invalid Named Object types.
    Example
    Append to Link Chart
      //We create an id set to contain the records to be appended
      var dict = new Dictionary<string, List<long>>();
      dict["Suspects"] = new List<long>();
      //In this case, via results from a query...
      var qry2 = "MATCH (s:Suspects) RETURN s";
      await QueuedTask.Run(async () =>
        using (var kg_for_lc = kgLayer.GetDatastore())
          var graphQuery = new KnowledgeGraphQueryFilter()
            QueryText = qry2
          using (var kg_rc = kg_for_lc.SubmitQuery(graphQuery))
            while (await kg_rc.WaitForRowsAsync())
              while (kg_rc.MoveNext())
                using (var graphRow = kg_rc.Current)
                  var obj_val = graphRow[0] as KnowledgeGraphNamedObjectValue;
                  var oid = (long)obj_val.GetObjectID();
                  dict["Suspects"].Add(oid);
          //make an ID Set to append to the LinkChart
          var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg_for_lc, dict);
          //Get the relevant link chart to which records will be
          //appended...in this case, from an open map pane in the
          //Pro application...
          var mapPanes = FrameworkApplication.Panes.OfType<IMapPane>().ToList();
          var mapPane = mapPanes.First(
            mp => mp.MapView.IsLinkChartView &&
            mp.MapView.Map.Name == "Acme Link Chart");
          var linkChartMap = mapPane.MapView.Map;
          //or get the link chart from an item in the catalog...etc.,etc.
          //var projectItem = Project.Current.GetItems<MapProjectItem>()
          //      .FirstOrDefault(pi => pi.Name == "Acme Link Chart");
          //var linkChartMap = projectItem?.GetMap();
          //Call AppendToLinkChart with the id set
          if (linkChartMap.CanAppendToLinkChart(idSet))
            linkChartMap.AppendToLinkChart(idSet);
    Append to Link Chart from FFP Results
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      var linkChartView = MapView.Active;
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Append to Link Chart from FFP Results";
        //set up config
        var results = kg.RunFilteredFindPaths(ffp_config);
        var pathsEntitiesAndRelationships = results.ExtractPathsEntitiesAndRelationships(null);
        //Create a KG layer id set
        var kgLayerIdSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
          pathsEntitiesAndRelationships.ToKnowledgeGraphIDSet(
            KGResultContentFromFFP.EntitiesAndRelationships));
        var map = linkChartView.Map;
        if (!map.CanAppendToLinkChart(kgLayerIdSet))
          return;//not compatible
        map.AppendToLinkChart(kgLayerIdSet);
        //switch layout algo
        var algo = linkChartView.GetLinkChartLayout();
        if (algo != KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom)
          //Change layout algo to match the default used by the UI after FFP
          await linkChartView.SetLinkChartLayoutAsync(
            KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom);
        //To set link chart root nodes see 'Create Link Chart from FFP Results'
    Requirements
    ArcGIS Pro version: 3.3 or higher.
