ArcGIS.Core.CIM Namespace / CIMLASPointSplatter Class
Properties Methods Events
    CIMLASPointSplatter Class Members
    The following tables list the members exposed by CIMLASPointSplatter.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the size of rendered LAS points when Fixed or RealWorld point sizing are used. If real-world sizing is used, the value is represented in meters; otherwise the value is in screen-based points.
    Public Property Gets or sets the method used to determine the rendering size of LAS points. In 2D, only FixedAutoScale is supported.
    Public Property Gets or sets splat minimum size.
    Public Property Gets or sets splat scale.
    Public Property Gets or sets a value indicating whether to use splat highlighting.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLASPointSplatter.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLASPointSplatter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLASPointSplatter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
