ArcGIS.Desktop.Mapping Namespace / IMapFactory Interface / CreateLinkChart Method / CreateLinkChart(String,Uri,KnowledgeGraphLayerIDSet) Method
The name of the map.
A Uri link to a knowledge graph service.
A set of Named Object types and record ids that sets the content of the Knowledge Graph layer. See KnowledgeGraphLayerIDSet.
    Creates a link chart map (a map of type MapType.LinkChart) with a specified knowledge graph service. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function CreateLinkChart( _
       ByVal name As String, _
       ByVal knowledgeGraphServiceUri As Uri, _
       ByVal idSet As KnowledgeGraphLayerIDSet _
    ) As Map
    Parameters
    name
    idSet
    Return Value
    A map of type MapType.LinkChart.
    Exceptions
    ExceptionDescription
    knowledgeGraphServiceUri cannot be null.
    idSet contains invalid Name Object types..
    Remarks
    The KnowledgeGraph layer created in the Link Chart contains sub layers for each Named Object type. To set the output content of the KnowledgeGraph composite layer, add an entry to the idSet for each Named Object type to be included in the output along with a list of their relevant record ids. Specify a null or empty list for a given entry to include all the records for that particular type at the time of creation.
    Note: Named Object names in a ID set entry are case-sensitive.
    If there are Named Object type names specified in the ID set that do not match a Named Object type name in the KnowledgeGraph then a KnowledgeGraphLayerException will be thrown when the layer is created. The exception will contain the list of invalid Named Object types.
    If you specify a null or empty IDSet, then the KnowledgeGraph layer will contain all the sub layers for the Named Object types but the sub layers will contain no content.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
