GetMaterialTexture Method
Gets a byte buffer representing the texture image for the specifed material.
Syntax
Parameters
- materialIndex
- The index of the material. Must be greater than or equal to zero and less than MaterialCount. Get the index for a patch by calling GetPatchMaterialIndex.
Return Value
Byte buffer representing the texture image for the material. If the material is not textured, an array of size zero is returned.
Exceptions
Example
Multipatch Properties
int patchIndex = 0;
// standard geometry properties
bool hasZ = multipatch.HasZ;
bool hasM = multipatch.HasM;
bool hasID = multipatch.HasID;
bool isEmpty = multipatch.IsEmpty;
var sr = multipatch.SpatialReference;
// number of patches (parts)
int patchCount = multipatch.PartCount;
// number of points
int pointCount = multipatch.PointCount;
// retrieve the points as MapPoints
ReadOnlyPointCollection pointsMultipatch = multipatch.Points;
// or as 3D Coordinates
IReadOnlyList<Coordinate3D> coordinates = multipatch.Copy3DCoordinatesToList();
// multipatch materials
bool hasMaterials = multipatch.HasMaterials;
int materialCount = multipatch.MaterialCount;
// multipatch textures
bool hasTextures = multipatch.HasTextures;
int textureVertexCount = multipatch.TextureVertexCount;
// normals
bool hasNormals = multipatch.HasNormals;
// properties for an individual patch (if multipatch.PartCount > 0)
int patchPriority = multipatch.GetPatchPriority(patchIndex);
PatchType patchType = multipatch.GetPatchType(patchIndex);
// patch points
int patchPointCount = multipatch.GetPatchPointCount(patchIndex);
int pointStartIndex = multipatch.GetPatchStartPointIndex(patchIndex);
// the patch Points are then the points in multipatch.Points from pointStartIndex to pointStartIndex + patchPointCount
// if the multipatch has materials
if (hasMaterials)
// does the patch have a material?
// materialIndex = -1 if the patch does not have a material;
// 0 <= materialIndex < materialCount if the patch does have materials
int materialIndex = multipatch.GetPatchMaterialIndex(patchIndex);
// properties for an individual material (if multipatch.MaterialCount > 0)
var color = multipatch.GetMaterialColor(materialIndex);
var edgeColor = multipatch.GetMaterialEdgeColor(materialIndex);
var edgeWidth = multipatch.GetMaterialEdgeWidth(materialIndex);
var shiness = multipatch.GetMaterialShininess(materialIndex);
var percent = multipatch.GetMaterialTransparencyPercent(materialIndex);
var cullBackFace = multipatch.IsMaterialCullBackFace(materialIndex);
// texture properties
bool isTextured = multipatch.IsMaterialTextured(materialIndex);
if (isTextured)
int columnCount = multipatch.GetMaterialTextureColumnCount(materialIndex);
int rowCount = multipatch.GetMaterialTextureRowCount(materialIndex);
int bpp = multipatch.GetMaterialTextureBytesPerPixel(materialIndex);
TextureCompressionType compressionType = multipatch.GetMaterialTextureCompressionType(materialIndex);
var texture = multipatch.GetMaterialTexture(materialIndex);
// texture coordinates (if multipatch.HasTextures = true)
if (hasTextures)
int numPatchTexturePoints = multipatch.GetPatchTextureVertexCount(patchIndex);
var coordinate2D = multipatch.GetPatchTextureCoordinate(patchIndex, 0);
ICollection<Coordinate2D> textureCoordinates = new List<Coordinate2D>(numPatchTexturePoints);
multipatch.GetPatchTextureCoordinates(patchIndex, ref textureCoordinates);
// patch normals (if multipatch.HasNormals = true)
if (hasNormals)
// number of normal coordinates = multipatch.GetPatchPointCount(patchIndex)
Coordinate3D patchNormal = multipatch.GetPatchNormal(patchIndex, 0);
ICollection<Coordinate3D> normalCoordinates = new List<Coordinate3D>(patchPointCount);
multipatch.GetPatchNormals(patchIndex, ref normalCoordinates);
Get the texture image of a multipatch
int patchIndex = 0;
if (!multipatch.IsMaterialTextured(materialIndex))
return;
string ext = compressionType == TextureCompressionType.CompressionJPEG ? ".jpg" : ".dat";
byte[] textureBuffer = multipatch.GetMaterialTexture(materialIndex);
Stream imageStream = new MemoryStream(textureBuffer);
System.Drawing.Image image = System.Drawing.Image.FromStream(imageStream);
image.Save(@"C:\temp\myImage" + ext);
Requirements
