ArcGIS.Core.Geometry Namespace / Multipatch Class / GetMaterialTextureCompressionType Method
The index of the material. Must be greater than or equal to zero and less than MaterialCount. Get the index for a patch by calling GetPatchMaterialIndex.
Example
    Gets the compression type of the byte buffer for the texture of the specified material.
    Syntax
    Public Function GetMaterialTextureCompressionType( _
       ByVal materialIndex As Integer _
    ) As TextureCompressionType
    public TextureCompressionType GetMaterialTextureCompressionType(
       int materialIndex
    Parameters
    materialIndex
    Return Value
    The TextureCompressionType of the byte buffer that is returned from GetMaterialTexture.
    Exceptions
    ExceptionDescription
    The material index must be >= 0.
    The material index must be less than the number of materials in the multipatch.
    Remarks
    If the compression type is TextureCompressionType.CompressionJPEG the buffer is a JPEG image. If the compression type is TextureCompressionType.CompressionNone the buffer is a pointer to a raw buffer containing image pixels starting from the top left corner in the row major order. The pixel size depends on the GetMaterialTextureBytesPerPixel value.
    Example
    Multipatch Properties
      int patchIndex = 0;
      // standard geometry properties
      bool hasZ = multipatch.HasZ;
      bool hasM = multipatch.HasM;
      bool hasID = multipatch.HasID;
      bool isEmpty = multipatch.IsEmpty;
      var sr = multipatch.SpatialReference;
      // number of patches (parts)
      int patchCount = multipatch.PartCount;
      // number of points
      int pointCount = multipatch.PointCount;
      // retrieve the points as MapPoints
      ReadOnlyPointCollection pointsMultipatch = multipatch.Points;
      // or as 3D Coordinates
      IReadOnlyList<Coordinate3D> coordinates = multipatch.Copy3DCoordinatesToList();
      // multipatch materials
      bool hasMaterials = multipatch.HasMaterials;
      int materialCount = multipatch.MaterialCount;
      // multipatch textures
      bool hasTextures = multipatch.HasTextures;
      int textureVertexCount = multipatch.TextureVertexCount;
      // normals
      bool hasNormals = multipatch.HasNormals;
      // properties for an individual patch (if multipatch.PartCount > 0)
      int patchPriority = multipatch.GetPatchPriority(patchIndex);
      PatchType patchType = multipatch.GetPatchType(patchIndex);
      // patch points
      int patchPointCount = multipatch.GetPatchPointCount(patchIndex);
      int pointStartIndex = multipatch.GetPatchStartPointIndex(patchIndex);
      // the patch Points are then the points in multipatch.Points from pointStartIndex to pointStartIndex + patchPointCount
      // if the multipatch has materials
      if (hasMaterials)
        // does the patch have a material?
        //   materialIndex = -1 if the patch does not have a material;
        //   0 <= materialIndex < materialCount if the patch does have materials
        int materialIndex = multipatch.GetPatchMaterialIndex(patchIndex);
        // properties for an individual material (if multipatch.MaterialCount > 0)
        var color = multipatch.GetMaterialColor(materialIndex);
        var edgeColor = multipatch.GetMaterialEdgeColor(materialIndex);
        var edgeWidth = multipatch.GetMaterialEdgeWidth(materialIndex);
        var shiness = multipatch.GetMaterialShininess(materialIndex);
        var percent = multipatch.GetMaterialTransparencyPercent(materialIndex);
        var cullBackFace = multipatch.IsMaterialCullBackFace(materialIndex);
        // texture properties
        bool isTextured = multipatch.IsMaterialTextured(materialIndex);
        if (isTextured)
          int columnCount = multipatch.GetMaterialTextureColumnCount(materialIndex);
          int rowCount = multipatch.GetMaterialTextureRowCount(materialIndex);
          int bpp = multipatch.GetMaterialTextureBytesPerPixel(materialIndex);
          TextureCompressionType compressionType = multipatch.GetMaterialTextureCompressionType(materialIndex);
          var texture = multipatch.GetMaterialTexture(materialIndex);
      // texture coordinates (if multipatch.HasTextures = true)
      if (hasTextures)
        int numPatchTexturePoints = multipatch.GetPatchTextureVertexCount(patchIndex);
        var coordinate2D = multipatch.GetPatchTextureCoordinate(patchIndex, 0);
        ICollection<Coordinate2D> textureCoordinates = new List<Coordinate2D>(numPatchTexturePoints);
        multipatch.GetPatchTextureCoordinates(patchIndex, ref textureCoordinates);
      // patch normals (if multipatch.HasNormals = true)
      if (hasNormals)
        //  number of normal coordinates = multipatch.GetPatchPointCount(patchIndex)
        Coordinate3D patchNormal = multipatch.GetPatchNormal(patchIndex, 0);
        ICollection<Coordinate3D> normalCoordinates = new List<Coordinate3D>(patchPointCount);
        multipatch.GetPatchNormals(patchIndex, ref normalCoordinates);
    Get the texture image of a multipatch
      int patchIndex = 0;
      if (!multipatch.IsMaterialTextured(materialIndex))
        return;
      string ext = compressionType == TextureCompressionType.CompressionJPEG ? ".jpg" : ".dat";
      byte[] textureBuffer = multipatch.GetMaterialTexture(materialIndex);
      Stream imageStream = new MemoryStream(textureBuffer);
      System.Drawing.Image image = System.Drawing.Image.FromStream(imageStream);
      image.Save(@"C:\temp\myImage" + ext);
    Requirements
