ArcGIS.Core.SystemCore Namespace / ArcGISSignOn Class
Properties Methods
    ArcGISSignOn Class Members
    The following tables list the members exposed by ArcGISSignOn.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic) Gets the singleton instance for ArcGISSignOn
    Top
    Public Methods
     NameDescription
    Public Method Ensures that a portal URI is formatted correctly.
    Public Method Check if the portal provided by the Uri is signed on. This method is for use in CoreHost applications only
    Public Method Set your SignOnHandler to receive challenge requests whenever a federated feature service requires authentication. This method is for use in CoreHost applications only.
    Public Method Sign in to the portal provided by the Uri. This method is for use in CoreHost applications only
    Public Method Sign out of the portal provided by the Uri. This method is for use in CoreHost applications only
    Top
