ArcGIS.Core.SystemCore Namespace / ArcGISSignOn Class / SignInWithCredentials Method
The uri of the portal to sign on to
The user name to use for credentails or null
The password to use for credentials or null
The referer to use with the access token
The returned access token
    SignInWithCredentials Method (ArcGISSignOn)
    Sign in to the portal provided by the Uri. This method is for use in CoreHost applications only
    Syntax
    public bool SignInWithCredentials(
       Uri portalUri,
       string user,
       string password,
       out string referer,
       out string token
    Public Function SignInWithCredentials( _
       ByVal portalUri As Uri, _
       ByVal user As String, _
       ByVal password As String, _
       ByRef referer As String, _
       ByRef token As String _
    ) As Boolean
    Parameters
    portalUri
    user
    password
    referer
    token
    Exceptions
    ExceptionDescription
    Invalid portal uri
    General system core exception; for example if a conversion combination is not supported.
    Remarks
    For use in CoreHost applications only. A SystemCoreException will be thrown if signon fails.
    CoreHost clients should not call this method in their code directly. Instead they should implement an ISignOnHandler that will be called back whenever a credential is required for a connection to a portal or online (e.g. a connection is being attempted to a federated feature service).
    Use SetSignonHandler to set your sign on handler. Within the ISignOnHandler.GenerateCredentials callback, CoreHost clients should call SignInWithCredentials to sign on passing in the portal URI provided to you via the GenerateCredentials SIGNONHANDLERINFO.agoURL parameter. The token and referer are returned for convenience but there is really no need to use them in your code unless you want to make your own REST calls to the federated portal(s) directly. Underlying feature services will automatically aquire the generated access token without you needing to do anything further.
    Requirements
