ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CreateLayers Method / CreateLayers(BulkLayerCreationParams,ILayerContainerEdit) Method
A BulkLayerCreationParams object.
A map or group layer where the Layers will be added.
Example
    Creates a readonly list of new Layer instances using the specified BulkLayerCreationParams and adds it to a container such as a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    layerParams
    container
    Return Value
    A Readonly list of Layer.
    Exceptions
    ExceptionDescription
    layerParams or container is null.
    An elevation surface layer cannot be used as a container for bulk layer creation.
    Unable to bulk create layers with a combination of standard and custom items.
    Unable to bulk create layers with data supplied as a mixture of Uris, Items and data connections.
    Unable to bulk create layers with the supplied child LayerCreationParams.
    Remarks
    The bulk layer creation process creates the layers it is able to per the data supplied. If invalid Uris, data connections or Items exist amongst valid data, there will be a mismatch in the number of layers created compared to the number of data items supplied. For example, 5 Uris are supplied, but only 4 layers are created because one of the Uris points to a dataset that does not exist. LayerFactory.CreateLayers will return the layers created, but no information regarding the invalid dataset. The only exception to this is if all datasets are invalid (and no layers are created); in this scenario an System.ArgumentException will be thrown.
    See the BulkLayerCreationParams.RollbackBehavior for information about rollback options with bulk layer creation when the BulkLayerCreationParams object is created with a set of LayerCreationParams objects.
    Example
    Create multiple layers with BulkLayerCreationParams 1
      //Uris to the datasets for the layers to be created
      var uriShp = new Uri(@"c:\data\roads.shp");
      var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
      var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
      // Create a list of URIs to be used for creating multiple layers
      var uris = new List<Uri>() { uriShp, uriSde, uri };
      // set the index and visibility
      var blkParams = new BulkLayerCreationParams(uris);
      blkParams.MapMemberPosition = MapMemberPosition.Index;
      blkParams.MapMemberIndex = 2;
      blkParams.IsVisible = false;
      // blkParams.AutoGroup = true;    AutoGroup is set to true by default
      // Create multiple layers using the BulkLayerCreationParams
      var layers = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayers(blkParams, map));
    Create multiple layers with BulkLayerCreationParams 1 - No AutoGroup
      // same example as "Create multiple layers with BulkLayerCreationParams 1" but without
      //   adding layers in a group layer
      blkParams.AutoGroup = false;
    Create multiple layers with BulkLayerCreationParams 2 - invalid
      // get a feature class that is selected in the catalog pane
      Item item = Project.GetCatalogPane().SelectedItems.FirstOrDefault();
      var lcpShp = new FeatureLayerCreationParams(uriShp);
      lcpShp.Name = "Roads";
      lcpShp.IsVisible = false;
      lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
      var lcpItem = new FeatureLayerCreationParams(item);
      lcpItem.Name = "Census Polygons";
      lcpItem.IsVisible = true;
      // list contains a Uri data source and an Item data source
      // LayerFactory.Instance.CreateLayers will throw an ArgumentException
      var lcps = new List<FeatureLayerCreationParams>();
      lcps.Add(lcpShp);
      lcps.Add(lcpItem);
      var blkParams = new BulkLayerCreationParams(lcps);
      // LayerFactory.Instance.CreateLayers will thrown an ArgumentException
      // because the LayerCreationParams are created using different
      // types of data sources (1 Uri and 1 Item)
    Create multiple layers with BulkLayerCreationParams 2 - Valid
      var lcpSde = new FeatureLayerCreationParams(uriSde);
      lcpSde.Name = "Census Polygons";
      lcpSde.IsVisible = true;
      var lcpService = new FeatureLayerCreationParams(uri);
      lcpService.Name = "Shelters";
      lcpService.IsVisible = true;
      // set some renderer here ...
      //lcpService.RendererDefinition = ...
      lcps.Add(lcpShp);
      lcps.Add(lcpSde);
      lcps.Add(lcpService);
      // set the positioning on the BulkLayerCreationParams
      blkParams.MapMemberIndex = 0;
    Create multiple layers with BulkLayerCreationParams 3 - Valid
      // illustrates using a collection of CIMLayerDocument
      var layerFile1 = @"c:\data\CitiesRivers.lyrx";
      var layerfile2 = @"c:\data\StatesWorld.lyrx";
      var layerDoc1 = new LayerDocument(layerFile1);
      var cimLayerDoc1 = layerDoc1.GetCIMLayerDocument();
      var layerDoc2 = new LayerDocument(layerfile2);
      var cimLayerDoc2 = layerDoc2.GetCIMLayerDocument();
      var cimLayerDocs = new List<CIMLayerDocument>() { cimLayerDoc1, cimLayerDoc2 };
      var blkParams = new BulkLayerCreationParams(cimLayerDocs);
      blkParams.AutoGroup = true;   // add the layersfiles within an encompassing group layer
    Create multiple layers with BulkLayerCreationParams - Using RollbackBehavior
      lcps.Add(lcpShp);
      lcps.Add(lcpSde);
      // set the rollback behavior
      // - rollback if one or more layers cannot be created due to an invalid data source
      blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
    Add a GeoPackage to the Map
      string pathToGeoPackage = @"C:\Data\Geopackage\flooding.gpkg";
      //Create lists to hold the URIs of the layers and tables in the geopackage
      var layerUris = new List<Uri>();
      var tableUris = new List<Uri>();
        //Create an item from the geopackage
        var item = ItemFactory.Instance.Create(pathToGeoPackage, ItemFactory.ItemType.PathItem);
        var children = item.GetItems();
        //Collect the table and spatial data in the geopackage
        foreach (var child in children)
          var childPath = child.Path;
          if (child.TypeID == "sqlite_table")
            tableUris.Add(new Uri(childPath));
          else
            layerUris.Add(new Uri(childPath));
        //Add the spatial data in the geopackage using the BulkLayerCreationParams
        if (layerUris.Count > 0)
          BulkLayerCreationParams bulklcp = new BulkLayerCreationParams(layerUris);
          LayerFactory.Instance.CreateLayers(bulklcp, map);
        // add the tables separately
        foreach (var tableUri in tableUris)
          StandaloneTableFactory.Instance.CreateStandaloneTable(tableUri, map);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
