ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / GetSelection Method
Example
    GetSelection Method (FeatureSceneLayer)
    Gets the current selection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Selection GetSelection()
    Public Function GetSelection() As Selection
    Return Value
    Exceptions
    ExceptionDescription
    No associated feature service
    Remarks
    GetSelection() can only be used on feature scene layers that have an associated feature service. Check HasAssociatedFeatureService property to determine if the FeatureSceneLayer has an associated feature service. Calling GetSelection() on a FeatureSceneLayer with no associated feature service will throw a System.InvalidOperationException
    Example
    Delete all the selected features in FeatureSceneLayer
      if (!featSceneLayer.HasAssociatedFeatureService ||
        !featSceneLayer.IsEditable)
        return;
      await QueuedTask.Run(() =>
        var delOp = new EditOperation()
          Name = "Delete selected features"
        //Assuming we have a selection on the layer...
        delOp.Delete(featSceneLayer, featSceneLayer.GetSelection().GetObjectIDs());
        delOp.ExecuteAsync();
    Requirements
