Public Overloads Sub Export( _ ByVal exportFormat As ExportFormat _ )
public void Export( ExportFormat exportFormat )
Parameters
- exportFormat
- Provides the information for the export output.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
| System.Exception | File path must be valid and file must be accessible. |
//Export a single page layout to PDF.
//Create a PDF format with appropriate settings
//BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
string filePath = @"Path and file name for the output export file";
PDFFormat PDF = new PDFFormat()
OutputFileName = filePath,
Resolution = 300,
DoCompressVectorGraphics = true,
DoEmbedFonts = true,
HasGeoRefInfo = true,
ImageCompression = ImageCompression.Adaptive,
ImageQuality = ImageQuality.Best,
LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
//Check to see if the path is valid and export
if (PDF.ValidateOutputFilePath())
//Note: Must be on QueuedTask.Run
layout.Export(PDF); //Export the layout to PDF on the worker thread
//Export a map frame to JPG.
//Create JPEG format with appropriate settings
//BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
JPEGFormat JPG = new JPEGFormat()
HasWorldFile = true,
Resolution = 300,
ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
Height = 800,
Width = 1200
//Reference the map frame
MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
//Export on the worker thread
//Note: Must be on QueuesTask.Run
if (JPG.ValidateOutputFilePath())
mf.Export(JPG); //Export the map frame to JPG
//Export the map view associated with a map frame to BMP.
//Create BMP format with appropriate settings
//EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
BMPFormat BMP = new BMPFormat()
Resolution = 300,
Height = 500,
Width = 800,
await QueuedTask.Run(() =>
MapView mv_bmp = mapFrame.GetMapView(layoutView);
if (mv_bmp != null)
if (BMP.ValidateOutputFilePath())
mv_bmp.Export(BMP); //Export to BMP
//Export a map series with multiple pages to a single PDF.
//Create PDF format with appropriate settings
PDFFormat MS_PDF = new PDFFormat()
Resolution = 300,
//Set up map series export options
MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
ExportPages = ExportPages.Custom, //Provide a specific list of pages
CustomPages = "1-3, 5", //Only used if ExportPages.Custom is set
ExportFileOptions = ExportFileOptions.ExportAsSinglePDF, //Export all pages to a single, multi-page PDF
ShowSelectedSymbology = false //Do no show selection symbology in the output
if (MS_PDF.ValidateOutputFilePath())
layout.Export(MS_PDF, MS_ExportOptions); //Export to PDF
//Export each page of a map series to an individual TIFF file.
//Create TIFF format with appropriate settings
TIFFFormat TIFF = new TIFFFormat()
Resolution = 300,
ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
HasGeoTiffTags = true,
ImageCompression = TIFFImageCompression.LZW
MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
ExportPages = ExportPages.All, //All pages
ExportFileOptions = ExportFileOptions.ExportMultipleNames, //Export each page to an individual file using page name as a suffix.
ShowSelectedSymbology = true //Include selection symbology in the output
//Note: Must be on the QueuedTask.Run()
if (TIFF.ValidateOutputFilePath())
layout.Export(TIFF, MSExportOptions_TIFF); //Export to TIFF
