ArcGIS.Core.CIM Namespace / CIMStatisticalDataCollectionFeatureLayerCalculator Class
Properties Methods Events
    CIMStatisticalDataCollectionFeatureLayerCalculator Class Members
    The following tables list the members exposed by CIMStatisticalDataCollectionFeatureLayerCalculator.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the data connection to apportionment dataset. This property is optional.
    Public Property Gets or sets the data connection to the source.
    Public Property Gets or sets the DatasetID which is used for getting the information about which points layer will be available and which apportionment methods will be used. If DatasetID is empty, only Area Apportionment method is available.
    Public Property Gets or sets the regular fields of the calculator.
    Public Property Gets or sets the Name of the calculator. (Inherited from ArcGIS.Core.CIM.CIMStatisticalDataCollectionCalculator)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStatisticalDataCollectionFeatureLayerCalculator.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStatisticalDataCollectionFeatureLayerCalculator with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStatisticalDataCollectionFeatureLayerCalculator and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
