ArcGIS.Core.CIM Namespace / CIMCutAndFillEADefinition Class
Properties Methods Events
    CIMCutAndFillEADefinition Class Members
    The following tables list the members exposed by CIMCutAndFillEADefinition.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the polygon indicating the area to cut the ground above and fill the ground below. Should be a level plane for best results.
    Public Property Gets or sets the id. (Inherited from ArcGIS.Core.CIM.CIMExploratoryAnalysisDefinition)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMCutAndFillEADefinition.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMCutAndFillEADefinition with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMCutAndFillEADefinition and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
