ArcGIS.Core.CIM Namespace / CIMLinkChart Class
    CIMLinkChart Class Properties
    For a list of all members of this type, see CIMLinkChart members.
    Public Properties
     NameDescription
    Public Property Gets or sets the link chart entities.
    Public Property Gets or sets a value indicating whether this link chart is expanded in the contents pane.
    Public Property Gets or sets a value indicating whether this link chart is filtered by the minimum number of links.
    Public Property Gets or sets the link chart filter groups.
    Public Property Gets or sets the URI of the binary reference containing the GraphML.
    Public Property Gets or sets a value indicating whether this link chart layout updates when the user moves nodes or links.
    Public Property Gets or sets the link chart layout algorithm.
    Public Property Gets or sets a value indicating whether this link chart is locked.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the minimum number of links allowed in the filter.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the link chart relationships.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the link chart viewport.
    Top
