ArcGIS.Core.CIM Namespace / CIMLinkChartEntity Class
Properties Methods Events
    CIMLinkChartEntity Class Members
    The following tables list the members exposed by CIMLinkChartEntity.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the node drawing information.
    Public Property Gets or sets a value indicating whether this entity is expanded in the contents pane.
    Public Property Gets or sets the Id of for the entity.
    Public Property Gets or sets the fields used to uniquely identify nodes. If duplicate values exist you can CollapseDuplicates.
    Public Property Gets or sets the field used to label nodes.
    Public Property Gets or sets the node labeling information.
    Public Property Gets or sets the CIMPath for the layer used to create the entity.
    Public Property Gets or sets the name of the entity.
    Public Property Gets or sets a value indicating whether the entity is non spatial. Where it has coordinates on the map. This is used to prevent drawing links on the map to the wrong nodes.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLinkChartEntity.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLinkChartEntity with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLinkChartEntity and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
