ArcGIS.Core.CIM Namespace / CIMLinkChartRelationship Class
Properties Methods Events
    CIMLinkChartRelationship Class Members
    The following tables list the members exposed by CIMLinkChartRelationship.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the link drawing information. This specifies the link color, width, and dash style.
    Public Property Gets or sets a value indicating whether this relationship is expanded in the contents pane.
    Public Property Gets or sets the Id of for the relationship.
    Public Property Gets or sets the KeyType. This specifies where the key fields are located.
    Public Property Gets or sets the link labeling information.
    Public Property Gets or sets the path to the foreign table or layer used to create the relationship.
    Public Property Gets or sets the name of the relationship.
    Public Property Gets or sets the source entity backing field for the relationship.
    Public Property Gets or sets the source entity id for the relationship.
    Public Property Gets or sets the source entity key field for the relationship.
    Public Property Gets or sets the target entity backing field for the relationship.
    Public Property Gets or sets the target entity id for the relationship.
    Public Property Gets or sets the target entity key field for the relationship.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLinkChartRelationship.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLinkChartRelationship with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLinkChartRelationship and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
